Map output of tracks
Topic: Map output of tracks
Hi everyone!
One costumer ask a function we don't know is it possible in Wialon or not. They want to print track of each vehicle in each day, It's simple, should create a report with map output of all messages. But, the problem is that tracks don't show movement direction in printed sheet. As you know even when you check vehicle's track in Wialon should zoom in to see movement direction. And basically it's impossible to zoom in paper map :-)
Any one have any idea for this issue?
Thanks you all
Re: Map output of tracks
You can try to use HTML format to export reports, the map with track will be saved as png file in archive
The png image will look sharper
Diana Cheley
Wialon Hosting Expert
if you put numbers it will tell you how it traveled
HTML Output doesn't work, Infact there is not much difference between PDF and HTML.
Regarding numbering which numbers you exactly mean?!!
I have a screenshot from other software. Is it possible to create something like below?
marker numbering in map output
Dear froend
I checked Marker Numbering but nothing happened. May you show me with a screenshot?
Thanks
her you go
Post's attachments
