Internet Explorer - script5 : Access Denied
Тема: Internet Explorer - script5 : Access Denied
Hi,
I have develop an application for internal use for the company I work for.
This web app gets the GPS location of my units and puts them on google maps.
I use the Javascript API for the code.
When I open this web app with Internet Explorer 11 some units won’t show anything on the map, even if there are GPS coordinates.
When I open the Developer Tools for debugging, I get the message SCRIPT5:Access Denied which points to the address : https://hst-api.wialon.com/wialon/post.html
That messages appears at page load.
At page load I do a login connection to Wialon.
function wialon_login(){
    wialon.core.Session.getInstance().initSession("https://hst-api.wialon.com"); // init session
    wialon.core.Session.getInstance().login("username", "pass", "", // try to login
    function (code) { // login callback
           // if error code - print error message
        if (code){ console.log(wialon.core.Errors.getErrorText(code)); return; }
    console.log("Logged successfully");
Can someone point me to a solution why I can’t get it to work with internet Explorer 11.
Everything work fine with Firefox & Google Chrome.
Thanks!
Re: Internet Explorer - script5 : Access Denied
Hi
Unfortunately i cant reproduce your problem.
I created small JSbin sample. For me it works in chrome & ie. Please check and confirm it works for you too.
Source http://jsbin.com/qehoqe/edit?js,output
Preview http://output.jsbin.com/qehoqe/
If this sample works fine in your IE, please try to create not working jsBin.
Hello!
Also, try to open the Developer Tool and check if the Document Mode sets to Standards. Maybe it helps.
Br. DK
Also, try to open browser settings and reduce the level of security.
Telegram: Обновления Wialon, Wialon updates
Google Chrome Extensions: Wialon Units Map | Gurtam Forum Notifications | Wialon Apps Launcher
Evgenij Spitsyn, Developer, flespi team
Thank you!  Also, verify if the Document Mode is set to Standards in the Developer Tool. Perhaps it will be of assistance.
