HI ,
You sorted this issue ? if otherwise let me know I can send you the configuration file.
to cut off power remotely - use the below command,
AT+GTOUT=gv300,1,,,0,0,0,0,0,0,0,,0,0,,,,FFFF$
to open it (release the engine)
AT+GTOUT=gv300,0,,,0,0,0,0,0,0,0,,0,0,,,,FFFF$
SoporteFolgenMx wrote:Hi guys, I need help to configure the Queclink GV300.
Im using the Manager Tool fot GV300, and Im stuck.
I can't make the SOS button notification with Wialong Hosting to pop-up. I mean actually I can't even make the SOS button works, it shows nothing when I press it, I don't know what Im doing wrong, but Im desperated.
I also need to make work a comand, I created a comand to cutt off the power of the unit by using relay remote cut off, but is not working properly, I don't get that option to activate output 1 or 2 or 3. I mean in this device is complicated. I neither understand those options and stuff about duration and toggle times. In deed I need support, just guide me. If anyone knows how to configure it please let me know. Im exhausted of thinking and not get in what I want. Sorry if my english is not perfect but I don't speak english perfect. I hope someone reply to my comment.
SOS button works.
Comand to cutt of the power by using relay remote cut off.
						Sint
