Coban GPS306
Topic: Coban GPS306
The new OBD tracker TK306 of Coban looks promising.
A lot good skills.
Known as TK306 , here it appears as GPS306.
http://gurtam.com/en/gps_tracking/gps_h … d=12082396
I did the setup according the manual, similier to other TK trackers but
i could not get it online.
Like to hear from others that work with it.
koby
Koby Karat
Ananas Global
Coban GPS306
Re: Coban GPS306
I had the same problem. Contact the support team to correct it.
Coban GPS306
Re: Coban GPS306
Koby,
would be interesting if you get Fuel Level on different vehicles!
Wolf.
P.S. hdavalos: what was the problem what support changed that it is running?
Coban GPS306
Re: Coban GPS306
Dear Wolf.
I still did not come back to it.
It did not work so i left it for a will.
the device  looks good so I will come back to it.
I focus on good tracking service with easy instalation,  so no fuel level.
Koby Karat
Ananas Global
Coban GPS306
Re: Coban GPS306
Hi Koby,
Just curious - are you looking to use this device for only track and trace?
Sergei.
Coban GPS306
Re: Coban GPS306
Hi.
Especialy for Tracking  yes.
Easy instalation.
and OBD information that can be read to the server.
Koby Karat
Ananas Global
Coban GPS306
Re: Coban GPS306
What OBD info are you looking to source?
Coban GPS306
Re: Coban GPS306
not sure exactlly what is important ,Can be :
engine temp
IGN  - very important
engine rpm
fuel level
fuel consumption
tracker voltage %
millage
Koby Karat
Ananas Global
Coban GPS306
Re: Coban GPS306
engine temp
engine rpm
fuel level
fuel consumption
tracker voltage %
millage
Do not expect much of this device, hardly read parameters.
Coban GPS306
Re: Coban GPS306
So far I have heard many confirmation from a variety of different manufacturers, that such parameters, as fuel level, consumption, eve ignition is a hit-or-miss depending on vehicle make and model of a vehicle.
Coban GPS306
Re: Coban GPS306
Hi Dear Sergei.
Good to get feedbacks.
I use Queclink GV500 OBD device. Works fine on Gurtam . IGN , RPM, temp .. ok.
Regarding Coban GPS306 I just want it to work, to do tracking.  Cheap device, can be very atractive.
A leading cheap trackers company.
I was asked here what elese i wish to have.
Just want to see GPS306 works with Gurtam.
Koby Karat
Ananas Global
Coban GPS306
Re: Coban GPS306
koby
yes, GPS306 is supported, but it is not very popular despite the fact of being cheap. Regarding their price: based on our experience this is just the case where going cheap you risk to have some inconveniences hereinafter. So if you decide to use them for your commercial purposes i'd suggest you to get one sample and test it like 10 times before implementing in a real project, this way investments in preliminary tests may save you a lot of nerves subsequently, That's almost like our famous expert Wolf has proven his experience while our last conference in Minsk (i'm sure you remember what i'm talking about), he got so much positive feedbacks and finally showed that his approach was 100% right, i believe he can add some more points about that.
Business Development Manager
Coban GPS306
Re: Coban GPS306
If Wolf has checked it then I understand.
Going back  to  Queclink GV500 (OBD device)  works perfect.
Sell & forget.
Koby Karat
Ananas Global
Coban GPS306
Re: Coban GPS306
Nice product!!!
Concox is a professional GPS Tracker manufacturer in China providing GPS vehicle tracking devices and mobile phone trackers all over the world in excellent quality at factory price www.iconcox.com
