Invalid service when requesting units or user
Тема: Invalid service when requesting units or user
Hi,
I use wialon sdk within backbone+requirejs+jquery mobile mobile application.
Every time I switch to page that has wialon login
wialon.core.Session.getInstance().login(username, password, "", // try to login
                        function (code) { // login callback
                            // if error code - print error message
                            if (code) {
console.log(wialon.core.Errors.getErrorText(code));
                                return;
                            console.log("Logged successfully");
I receive error code 2 or Invalid service error.
But when I refresh the switched page I successfully log.
Do you have any idea what could be the reason for this behaviour?
(22/10/2014 15:07:33 отредактировано spev)
Re: Invalid service when requesting units or user
Hi.
You must initialize the session and check if you are already logged in.
You can find example on Playground
var sess = wialon.core.Session.getInstance();
var user = sess.getCurrUser();
if( user ) { // Check state
    console.log("Already logged as '" + user.getName()+"'");
} else {
    sess.initSession("https://hst-api.wialon.com"); // initialize Wialon session
    sess.login(username, password, "",
                        function (code) {
                            if (code) {
                                return;
Telegram: Обновления Wialon, Wialon updates
Google Chrome Extensions: Wialon Units Map | Gurtam Forum Notifications | Wialon Apps Launcher
Evgenij Spitsyn, Developer, flespi team
Thanks a lot. That was the issue
