CSV to KML converter
Тема: CSV to KML converter
Hi guys,
we really need to find a converter, we have to upload 8k geofences to wialon hosting, geofences should be with this characteristic: radius 50m and marked as a source of address
we found this converter http://www.earthpoint.us/ExcelToKml.aspx but does not make radius or source address
anybody can help us ??
THANKS IN ADVANCE
Re: CSV to KML converter
Guess it would go easier via WLP file type. http://docs.gurtam.com/en/hosting/cms/port/exp-wlp
Export few POIs with radius and check the file in notepad++ or similar text editor.
Than follow the syntax of it
cttmx пишет:
Hi guys,
THANKS IN ADVANCE
The are special tags responsible for "address source" checkbox and radius.
1. Import geofences as they are. Than export them back. This step helps to optimize structure of kml file.
2. Open kml file in any text editor (NotePad++)
3. Use Find and Replace Tool:
   3.1. addr="0" to addr="1"  (the tag responsible for address source option)
   3.2. width="1000.0 to width="50.0
4, Import kml file to Wialon.
Maps Manager
Thanks !!! work perfect
by the way, we have sometimes also the demand of customers to convert their excel file with ADRESSES into geofences.
Problem here is the conversion of adresses into latitude/longitude.
Does anybody know a "lookup-tool" for this?
Thanks
Wolf.
Hello, Wolf.
First variant coming to my mind is this API call - http://sdk.wialon.com/wiki/en/sidebar/r … tes_simple
With an example here - http://sdk.wialon.com/wiki/en/sidebar/r … ss_coords/
BR.
Hi Serd,
cool!!! always cool to see how many functions api has.
Will ask Venellin to create a little SW to import xls file into Wialon....
Thanks
Wolf.
