custom configurable "private mode"
Тема: custom configurable "private mode"
Hi dear Partners and Gurtam Developers,
Wolf has a new "we make developers crazy" idea ;-) (based on 3 different customer requests and very uncommon in eastern europe as i think hihi):
Here "business" cars typicaly are used also for private at the end of the day. For this employes pay a monthly fee to be alowed to use this. If they dont use a "driving" logbook they wish to "disable" the tracking during the time of private trips and the european privacy act describes this situation very clear with the words "the user of a private used car must be able to disable any kind of gps tracking".
for this we have on some hardware a special firmware where user can "switch off" the saving of gps positions, but this is complicated (you need a switch, it must be mounted somehwere, you destroy some parts of the car, user forget to enable the system again and so on and so on).
So we was a view times requested by potential customers to have a function in the plattform to set a privacy mode like
"monday from 16:00-07:00 on next day", tuesday etc same, Friday from 14:00-Monday 07:00" (i am sure there are more easy ways to explain that)
in this times the receiving script should realy NOT SAVE the data from this objects.
And the 150% solution would be, if i can add some "holiday time" like "from 02.11.2014-14.11.2014" :-))
Anybody else who would like to have this? I dont know any competitor who can provide such nice thing....
Wolf.
Re: custom configurable "private mode"
wwbusch, you can implement this with jobs: schedule them with activation/deactivation command at desired day/time.
Hi Shal,
do you mean by sending a command to the Unit?
I just checked our mainly used FM1100 devices manual for any command to block position aquiring without loosing gprs connection but did not find any way for that and SMS sending = expensive here in germany (0,13 USD/SMS)
Thanks for additional tips,
Wolf.
Hi Wolf on the FM1100 you could set up an automated  process to change the aquisition time to be a long time between records for the private recordings and then use a job to delete the records in the device buffer using a job. Look at the commands in the manual under 8.5 aquisition modes.
Having the ability to ignore incomming records in Wialon for a period of time is a good idea
John
Phoenix Solusi
Mobile Visible Secure
Hi John,
so idea would be:
let device very seldom save position data and than send device a command to delete buffer?
Wolf.
(which is a way back threw the nose to the ears winding threw the brain and back to mouth, just to "not store some data", but maybe a possible solution also i think a function in Wialon would be much nicer :-)
Yes Wolf infact the message would never get to wialon as the buffer would be flushed before the send so nothing to send.
Phoenix Solusi
It should be like a place in wialon where partners can draw the schedule including the holidays
then as soon as the sever receives messages falling it the specified period it deletes it automatically and instantly
and also you configure  Teltonika F1100  data aquisition time  as well for not sending data falling in these period
Regards
Yoosouf Parvez
From Startouch
Mobile : +23057631200
