Re: Using OpenCellID Database for Position Lookup if no GPS Avaiable
Hi Shal,
here is a case for your debug guys :-)
Device "GORDON" = VT310, it tells for MCC=106 but that is hexadecimal.
(rest of data is also hex as i remember), so that does not work with LBS lookup...
I know that some HW sends data as HEX and some as decimal, so how Wialon handle that?Wolf.
Hello Wolf.
LBS detector considers mcc to be a decimal value. We verified in the protocol. You are correct: VT310 sends mcc in a hexadecimal format. We will make necessary changes in the beginning of the next week. Mcc=106 will be registered as mcc=262. LBS Detector must work then.
