How to remove wrong max speed from the report
Тема: How to remove wrong max speed from the report
Hi,
I want know one thing that sometimes the tracking device sends the invalid message with the speed more then 150km/hr which is due to the jumping of the coordinates.I have already checked with the ADVANCE setting in the unit property but still the wrong max speed showing in the report.
So please advice to rectify this issue.
Re: How to remove wrong max speed from the report
If you talk about Enable filtration with parameter Maximum speed (for example you set it 150 km/h) Filter will be applied only for a next (future) messages
You should just delete the old not valid messages which received before set filtration
Diana Cheley
Wialon Hosting Expert
Thankyou very much for your guidance.
