How to get fuel theft in the report
Topic: How to get fuel theft in the report
Hi,
I am having problem with one of my unit in which fuel level senor is installed in the genset.The clever Genset operator first disconnect the fuel sensor from the tracking device then had done theft after that on the next day,he again reconnect the sensor,but the problem is that the wialon not showing the fuel theft in report but it showing in the fuel graph and i have also play with the settings but still it no showing the fuel theft.
So is there any possible way to get this fuel theft in the report.??
Re: How to get fuel theft in the report
dear rohin.k
as you know Wialon analyzes the incoming data from the device and it needs to be examined thoroughly at our end in order to detect the precise reason of such report.
Please forward a request to support@gurtam.com, enclose all necessary details, our specialists will check the info, explain the report result and give advices on how to set optimized fuel settings for your case.
Business Development Manager
We also need a similar report plus alerting to see if theft has happened over night. It needs to compare the previous fuel reading with the current one sent to see if there is a difference. It needs to be triggered when in a particular Geozone like the home location.
Phoenix Solusi
Mobile Visible Secure
I can tell what situation was there... There was disconnection of power supply. It was done by operator. There was a fuel theft. But by the inputs i can see that power supply was off. Ca we use validation by power supply? Will it show the fuel theft in that case?
Евгений
Technoton Sensors Pvt. Ltd., India
http://technoton.in
shpak,
As I understand you when a power supply is disconnecting it may be a theft
Does it mean that device doesn't send a data of fuel level?
If device sends a data of fuel level in this case but it's not valid you can apply a validation of power supply to FLS sensor in unit. It's useful
In any case a theft will be detected if final fuel level less than initial fuel level on considered interval
You can read more about thefts detection here http://docs.gurtam.com/en/hosting/user/ … ect_thefts
or write to support@gurtam.com, enclose all necessary details
Diana Cheley
Wialon Hosting Expert
Dear rohin,
i have installed technoton fuel sensor for three of my clients vehicle. i have no clue on how to setup fuel theft. plz kindly assist.
Warmest Regards,
Yusuf.
You can get a device which is anti-theft in the list of our products.
Concox is a professional GPS Tracker manufacturer in China providing GPS vehicle tracking devices and mobile phone trackers all over the world in excellent quality at factory price www.iconcox.com
