Queclink GV55
Topic: Queclink GV55
Hello,
One of our customer has GV55 and GV55 lite units. We have to direct these units to Wialon.
Has anyone got a configurator and user manual for Queclink units?
Regards,
Krisztián
Eflotta Vehicle Tracking Ltd, Hungary
www.eflotta.com
Queclink GV55
Re: Queclink GV55
Hi Kristian,
Try here :  sam.sang@queclink.com
This is the technical guy there
Goodluck
Baltika
Queclink GV55
Re: Queclink GV55
Hi.
I use Queclink GV-55 .
Works great for long time.
Now I connected the ignition input but how do i set a sensor on Wialon to get staus of the engine (off/on) ?
Thanks
koby
Koby Karat
Ananas Global
Queclink GV55
Re: Queclink GV55
koby
is this about digital input?
basically all you need is to define the right parameter in messages from the unit, then to create a sensor based on it. What parameter changes when the ignitiion is ON/OFF? may be I/O...
Business Development Manager
Queclink GV55
Re: Queclink GV55
Hi Poal.
The right parameter messages are defined ok in the Device.
I sent the configuration file to the Support of Queclink, they aproved it as OK.
It will report +RESP:GTIGN/+RESP:GTIGF to the backend server.    (GTIGN = ign on   GTIIF = ign off ).
Do you handle this message?
I am not sure how to set up the parameters of the software sensor for the unit on Wialon Hosting.
Thanks alot.
koby
Koby Karat
Ananas Global
Queclink GV55
Re: Queclink GV55
koby
give me access to this unit in PM - will try to find out the right param
Queclink GV55
Re: Queclink GV55
Hi Poal.
Hope you saw my PM.
You have all the rights.
Waiting patiently.
koby
poal wrote:
koby
Koby Karat
Ananas Global
Queclink GV55
Re: Queclink GV55
koby
find the answer in your PM, please
if you have some more questions don't be shy to write me
