search items error
Topic: search items error
Dear All,
Our coders run into this, when testing the SDK possibilities for the first time:
request:
https://hst-api.wialon.com/wialon/ajax. … 2013%22%7D
response: {
  "host": "46.107.68.128",
  "eid": "4d0c355f76039a984859aed6839307e8",
  "au": "eflottademo",
  "tm": 1371628555,
  "user": {
    "nm": "eflottademo",
    "cls": 1,
    "id": 156890,
    "prp": {
      "addr_provider": "map_webgis",
      "cfmt": "0",
      "dst": "-1",
      "evt_flags": "2",
      "fpnl": "monitoring",
      "language": "hu",
      "last_tail_points": "50",
      "minimap_zoom_level": "15",
      "mondv": "[\"156891_1\"]",
      "mont": "1",
      "monu": "[\"194822\",\"419681\",\"584670\"]",
      "monuv": "[\"194822\",\"419681\",\"584670\"]",
      "msc": "1",
      "mtg": "1",
      "mtgy": "0",
      "mu_cmd_btn": "0",
      "mu_delete_from_list": "0",
      "mu_events": "0",
      "mu_gps": "1",
      "mu_gps_mode": "0",
      "mu_gps_time": "0",
      "mu_loc_mode": "0",
      "mu_location": "0",
      "mu_move": "1",
      "mu_photo": "0",
      "mu_tracks": "1",
      "mu_tracks_ival": "0",
      "mu_watch": "1",
      "muf": "1027",
      "muow": "584670",
      "poil": "[\"156891_1\"]",
      "radd": "{\"w\":\"4\",\"c\":0,\"u\":419681,\"a\":1,\"td\":1,\"s\":\"default\"}",
      "show_log": "0",
      "tz": "184749584",
      "umap": "Google Streets",
      "umsp": "19.2048823,47.61340164287031,8",
      "ursstp": "0x17bf",
      "us_addr_fmt": "1255211008_10_5",
      "vsplit_block_left_panel": "381.4102478027344",
      "vsplit_monitoring_map_target": "200",
      "vsplit_report_templates_filter_target": "325",
      "znsn": "1"
    "crt": 154093,
    "bact": 156891,
    "fl": 22,
    "hm": "",
    "uacl": 2097795
  "classes": {
    "avl_hw": 4,
    "avl_resource": 3,
    "avl_retranslator": 7,
    "avl_route": 6,
    "avl_unit": 2,
    "avl_unit_group": 5,
    "user": 1
request:https://hst-api.wialon.com/wialon/ajax.html?svc=core%2Fsearch_item&sid=4d0c355f76039a984859aed6839307e8&params=%7B%22spec%22%3A%7B%22itemsType%22%3A%22name%22%2C%22propName%22%3A%22sys_name%22%2C%22propValueMask%22%3A%22*%22%2C%22sortType%22%3A%22sys_name%22%7D%2C%22force%22%3A1%2C%22flags%22%3A1%2C%22from%22%3A0%2C%22to%22%3A0%7D
response:
{"error":4}
or:
request:https://hst-api.wialon.com/wialon/ajax.html?svc=core%2Fsearch_item&sid=4d0c355f76039a984859aed6839307e8&params=%7B%22spec%22%3A%7B%22itemsType%22%3A%22name%22%2C%22propName%22%3A%22sys_name%22%2C%22propValueMask%22%3A%22*%22%2C%22sortType%22%3A%22sys_name%22%2C%22propType%22%3A%22list%22%7D%2C%22force%22%3A1%2C%22flags%22%3A1%2C%22from%22%3A0%2C%22to%22%3A0%7D
response:
{"error":4}
Thanks for your help,
Gergely
Eflotta Vehicle Tracking Ltd, Hungary
www.eflotta.com
search items error
Re: search items error
Dear Gergely,
your coders are using bad "itemsType" value, it must be one of the following:
avl_hw
avl_resource
avl_retranslator
avl_unit – unit
avl_unit_group
user
avl_route.
Developer
search items error
duig wrote:
Dear Gergely,
avl_hw
avl_resource
avl_retranslator
avl_unit – unit
avl_unit_group
user
avl_route.
Dear Igor,
Thanks for your help but no success yet,
The SDK says:
Search items by property
For more complicated searches, the request core/search_items is used. For example, all users can be found by making the following request:https://hst-api.wialon.com/wialon/ajax.html?svc=core/search_items&
        params={
               "spec":{
                      "itemsType":"user",
                       "propName":"sys_name",
                       "propValueMask":"*",
                       "sortType":"sys_name"
                "force":1,
               "flags":1,
               "from":0,
               "to":0
        }&sid=<your_sid>
Nevertheless, the results:
request:https://hst-api.wialon.com/wialon/ajax.html?svc=core%2Flogin&params=%7B%22user%22%3A%22eflottademo%22%2C%22password%22%3A%22demo2013%22%7D
response:{"host":"188.36.241.190","eid":"81f296768b1649abca0ee64c8fe00a89","au":"eflottademo","tm":1371750233,"user":{"nm":"eflottademo","cls":1,"id":156890,"prp":{"addr_provider":"map_webgis","cfmt":"0","dst":"-1","evt_flags":"2","fpnl":"monitoring","language":"hu","last_tail_points":"50","minimap_zoom_level":"15","mondv":"[\"156891_1\"]","mont":"1","monu":"[\"194822\",\"419681\",\"584670\"]","monuv":"[\"194822\",\"419681\",\"584670\"]","msc":"1","mtg":"1","mtgy":"0","mu_cmd_btn":"0","mu_delete_from_list":"0","mu_events":"0","mu_gps":"1","mu_gps_mode":"0","mu_gps_time":"0","mu_loc_mode":"0","mu_location":"0","mu_move":"1","mu_photo":"0","mu_tracks":"1","mu_tracks_ival":"0","mu_watch":"1","muf":"1027","muow":"584670","poil":"[\"156891_1\"]","radd":"{\"w\":\"4\",\"c\":0,\"u\":419681,\"a\":1,\"td\":1,\"s\":\"default\"}","show_log":"0","tz":"184749584","umap":"Google Streets","umsp":"19.2048823,47.61340164287031,8","ursstp":"0x17bf","us_addr_fmt":"1255211008_10_5","vsplit_block_left_panel":"381.4102478027344","vsplit_monitoring_map_target":"200","vsplit_report_templates_filter_target":"325","znsn":"1"},"crt":154093,"bact":156891,"fl":22,"hm":"","uacl":2097795},"classes":{"avl_hw":4,"avl_resource":3,"avl_retranslator":7,"avl_route":6,"avl_unit":2,"avl_unit_group":5,"user":1}}
request:https://hst-api.wialon.com/wialon/ajax.html?svc=core%2Fsearch_item&sid=&params=%7B%22spec%22%3A%7B%22itemsType%22%3A%22user%22%2C%22propName%22%3A%22sys_name%22%2C%22propValueMask%22%3A%22*%22%2C%22sortType%22%3A%22sys_name%22%7D%2C%22force%22%3A1%2C%22flags%22%3A1%2C%22from%22%3A0%2C%22to%22%3A0%7D
response: {"error":4}
Could you please send us an example req/resp from the login to the response with the unit IDs?
Many thanks in advance,
Gergely
www.eflotta.com
search items error
We have some examples at Wialon Development portal.
Remote API examples include "Login/logout" and "Item search" which you need.
Mobile Development
search items error
As far as I understand, this request is made from your examples. What is the exact problem with it?
www.eflotta.com
search items error
Eflotta
This examples don't have any problems. Search for itemsType="user" returns zero users because user wialon_test doesn't has access to other users. If you change itemsType to avl_unit, you get next response with 15 units.
{"searchSpec":{"itemsType":"avl_unit","propName":"sys_name","propValueMask":"*","sortType":"sys_name","propType":""},"dataFlags":1,"totalItemsCount":15,"indexFrom":0,"indexTo":0,"items":[{"nm":"#RoadKey","cls":2,"id":893061,"uacl":-1},{"nm":"361654","cls":2,"id":880677,"uacl":-1},{"nm":"361654","cls":2,"id":890803,"uacl":-1},{"nm":"ADM100_vologda","cls":2,"id":883606,"uacl":-1},{"nm":"Audi_retr","cls":2,"id":717361,"uacl":545},{"nm":"Bavarian Tractor","cls":2,"id":717359,"uacl":545},{"nm":"F370","cls":2,"id":882423,"uacl":-1},{"nm":"F6627","cls":2,"id":886295,"uacl":-1},{"nm":"FM Blue","cls":2,"id":890493,"uacl":-1},{"nm":"G400","cls":2,"id":883520,"uacl":-1},{"nm":"g400","cls":2,"id":884383,"uacl":-1},{"nm":"sch1","cls":2,"id":887137,"uacl":-1},{"nm":"usk86","cls":2,"id":886321,"uacl":-1},{"nm":"Новый объект","cls":2,"id":891671,"uacl":-1},{"nm":"Т-Хелпер","cls":2,"id":881338,"uacl":-1}]}
Requests:
1. https://hst-api.wialon.com/wialon/ajax.html?svc=core/login&params={"user":"wialon_test","password":"test"}
2. https://hst-api.wialon.com/wialon/ajax.html?svc=core/search_items&params={"spec":{"itemsType":"avl_unit","propName":"sys_name","propValueMask":"*","sortType":"sys_name"},"force":1,"flags":1,"from":0,"to":0}&sid=<your_sid>
Mobile Development
