Topic: WLP file and reports
Hy.
Im using wialone for 1st time and now I need to make some reports. Only what I can get is wlp file and dont know how to open it.
Can u help me with opening wlp files and tell me how to make reports for my boss?
Ty
Hy.
Ty
oops, wlp has nothing to do with reports and can't be used for, that's just a config file where for example exported settings of an unit are stored
In reports there is a separate button for reports export, so just execute it and press export to file.
http://docs.gurtam.com/en/hosting/user/ … ery/export
choose PDF, Excel or some other supported types
Ok....So I need to go on Reports and chose unit and then export??
Sry, but i will ask many questions about wialone cause Im new here..,
And if I may ask... Our working hours on tractors and in wialone isnt same, on some tractors is deference 20 working hours...
What can I do?
ty
What can I do?
ty
1. Reports are the inseparable part of Wialon, so you should choose report template, unit, period, then press Execute and then Export
you may go simpler and use Jobs
http://docs.gurtam.com/en/hosting/user/jobs/rep
2. I think there is a mistake in the ignition sensor configuration, engine hours depend on that.
So, I can use real working hourse and corect them in wialone and he would work corectly?
And one more thing...Here I got no decimal, like 2500,5 in tractor just on 2500 or 2501...can I change that somehow?
Ty
Ty
2. Yes, having connected ignition and having created an appropriate sensor you will have an opportunity to get the real working hours
You may just fill the calculation table for the sensor in order to define the range of working state, for example 2500,5=ON (1) and 2490=OFF (0) or whatever you need
also you may have operations upon parameters' values, for example having set it like adc1*const10 you'll convert 2500,5 coming from adc1 to 25005 if it's preferable
http://docs.gurtam.com/en/hosting/cms/u … nsors/calc
http://docs.gurtam.com/en/hosting/cms/u … sors/param
