Continous drive monitoring
Тема: Continous drive monitoring
We want to monitor if a vehicle and/or driver do a 2 hours continuous drive at one time / in one go through a report or an alert. The report should only show those drives that are 2 hours or more and if possible an alert should be generated when such happens.
Any idea how this is possible at gurtam?
Regards,
Ahmad.
Re: Continous drive monitoring
you must do that on the configure of the engine or trip report , changing the duration as a max of 2 hr , hour can arrange on the notifications also that the duration of the sate should be  2 hr.
what you want can be configured ....
if you need more info of how to configure please see this
http://docs.gurtam.com/en/hosting/user/ … filtration
If it is just an alert that you want you can use notifications. We have set up a group that is called 1 hour idle and we have a notification that checks if a vehicle has been idle for more than an hour and it generates an on screen alert plus generates an email and logs an event. It also moves the unit into the 1 hour idle group so that at any time we can click on the group and see all vehicles nation wide that have been idle for longer than an hour.
We then have a job that sends reports out every 4 hours for the regional PIC's to respond that an investigation has been carried out.
Regards
John
Phoenix Solusi
Mobile Visible Secure
