Visualizing a single unit from a group
Topic: Visualizing a single unit from a group
Is it possible to have in a future release the capability to visualise a particular unit in a group bu clicking on the unit in the group list that comes up.
Many times we are working with groups and we want to look at a particular unit in that group and at the moment we have to remove the groups from the monitoring list and change to units and then bring up the unit we are interested in.
It would be simpler and more effective if we could just click on the unit in the unit list that comes up when we mouse over a group.
Regards
John
Phoenix Solusi
Mobile Visible Secure
Re: Visualizing a single unit from a group
Предложение следующее:
В режиме мониторинга по группам нужна возможность центрировать карту на отдельном объекте. Объект выбирается простым щелчком мыши - из списка объектов, который всплывает при наведении курсора на название группы.
Основание:
В текущей реализации для того, чтобы центрировать на карте какой-то конкретный объект, нужно переключаться из режима мониторинга по группам в режим мониторинга по объектам.
Katerina Alexandrova
Product Manager (Mobile)
Hi Alek,
Your response is probably very relevant but I cannot read it as I am not a Russian speaker.
Regards
John
Phoenix Solusi
JohnG,
alek wrote a translation of your proposal for Russian speakers.
Mobile Development
JohnG, the feature you ask about will be available soon. There'll be a possibility to open/close units list in group view.
the same topic we have in Russian. Группировка объектов по группам
Aliakasandr i have seen the additional features and it is great thanks to the development team. Will the same capability be alos incorporated into PRO?
Regards
John
Phoenix Solusi
JohnG, as it was recently anounced, Wialon Pro just had it final version released. http://gurtam.com/en/news.html?n=20131224 (without that grouping capability)
All new reatures of Wialon Hosting would be available in our new server solution - Wialon Local. http://gurtam.com/en/news.html?n=20131216
And, yes, it is possible to upgrade from Wialon Pro to Wialon Local, if you wish so.
