Visualizing stopped points in a track
Тема: Visualizing stopped points in a track
I know that we can have different colours for the speed on a track but is it possible to see each of the points where a vehicle had stopped for longer than a predetermined time, say 5 minutes, as a standard part of the track visualization?
Regards
John
Phoenix Solusi
Mobile Visible Secure
Re: Visualizing stopped points in a track
Hi John
if you use reports to show a track it shows you the stops as P sign,
Reports also show different colours for different Speed if you enable it in configuration.
(we are always talking about Wialon Hosting)
Wolf.
Hi Wolf,
We have both the hosted and Pro solution and the client that is using Pro wants to see the stop points during monitoring as it may indicate that theft is happening. We are using reports but the client want it to be near real time so we have to show it in monitoring.
Regards
John
Phoenix Solusi
Well, in this case you can just configure trip-detection (for example by not moving more than 5 minutes or so) and than in monitoring it shows if device is moving or not (coresponding to your definition what is a stop point).
so it depends of how you use ignition.
but in wialon you not need to use ignition for status of movement.
Wolf.
P.S. i think that (as always) with a bit of configuration and playing you can configure everything as you need it!
Hi Wolf,
I have started looking at what can be done using using notifications and reporting.
Will let you know how I go.
Regards
John
Phoenix Solusi
If you need any help please let me know (but only for wialon hosting as i have no wialon pro in access)
Wolf.
Thanks for the offer Wolf,
I will be working on this over the weekend and will let you know if i run into trouble.
Regards
John
Phoenix Solusi
