Topic: Trax S6 Configure your TRAX Data S6
Hello everyone, here I leave the description of the values to set the S6 TRAX
TRAX SETTINGS S6
 MODIFIED BY: Francisco Nuñez
 CREATION DATE: HOME-15-04-11
 VERSION: FINAL S6 V.5.00
 CHANGES: (MADE ON THE INFO V.4.99)
COMPUTER PROGRAMMING - SET OF VARIABLES
> SFD55AA <FACTORY EQUIPMENT SET DEFAULT
> SGR ba.amx, ctigprs, ctigprs999 <SET FOR GPRS APN
> SIP0 193.193.165.165 <IP0 SET AS PRIMARY
> SIP1 193.193.165.165 <SET AS SECONDARY IP1
> SSU20293 <SET PORT LOCAL UDP
> SDU20293 <SET REMOTE PORT UDP
> SSM0 .100010000100009898 <SET PHONE NUMBER TO SEND MESSAGE --- New ---
> SGR * <SET RESET MODEM TO TAKE APN - (Set to be removed later)
> STD00000060000000 <SET TD 00 EVERY 30 MIN. NO DISTANCE - (Parameter ROAMING)
> STD01001000000000 <SET TD 01 EVERY 5 MIN. NO DISTANCE - (Parameter not used)
> STD02000100000300 <SET TD 02 EVERY 300 METERS OR EVERY 10 MINUTES
> STD03000000000300 <SET TD 03 EVERY 300 METERS
> STD04000120000000 <REPORT OF EACH TEMPERATURE 2MIN (modifiable) SENSOR GTE (4800 SERIAL TR1)
> STD05000120000000 <REPORT OF EACH TEMPERATURE 2MIN (modifiable) USING ANALOG INPUT 0 INO4 (GRIS)
> SIT1010010 <SET ENT. 1 WITH ANTI REBOUND 1 SEC 1 SEC OPEN GROUND
> SIT2010020 <SET ENT. 2 WITH ANTI REBOUND 1 SEC 1 SEC OPEN GROUND
> SIT6100100 <SET ENT. 6 debounce BATTERY WITH A POSITIVE FOR 10 SEC 10 SEC OPEN
> SIT7100100 <SET ENT. 7 debounce CONTACT OF A POSITIVE 10 SEC 10 SEC OPEN
> SGS00000010 <SET SPEED. VEHICLE FOR DETENTION
> SGS01000080 <SET SPEED. EXESO FOR DETECTION OF A 80 KM / H
> SAU0000000 <SET OFF ON OUTPUT 0 NO TIME AS ACTIVE
> SAU1000000 <AS SET OUT 1 NO TIME OFF ON ACTIVE
> SAU2000000 <2 AS SET OUT ON TIME OFF WITHOUT ACTIVE
> SDC01 * 045 <SET ANG. DRAWING FOR CHANGE OF ADDRESS TO 45 DEGREES
> SKO999999991800 <SET LOW
> SAR000211001900 <LEVELS SET AUXILIARY 12 VOLT BATTERY
> SAR010222004000 <LEVELS SET AUXILIARY 24 VOLT BATTERY
> SAR020003401400 <SET OF ANALOG INPUT VIVELES 0 IN04 (range 3.40 - 12 VOLTS)
> SAR030103501400 <
> SAR040000501400 <SUPERVISION OR CUT OR ANALOG INPUT IN4
> SCC0000090 <TIMER FOR GENERATING SET DELAY IN THE DETECTION. THE BAT. TO START THE SYSTEM
> SCC0400002 <
> SCT0000050 <RENVIOS SET COUNTER REPORT FOR CHANGE IP
> SUC01 QPI, 4.35 | QTX00, 7.99 | # <THROUGH THIS LINE MAY BE A REPORT WITH DATA visualize AWG THROUGH SENSOR
> SUC02 QAD, 4.99 | $ - Temperature = | # <THROUGH THIS LINE MAY BE A REPORT WITH DATA visualize
                                                        TEMPERATURE USING ANALOG INPUT VOLTAGE 0 IN04
> STX00CS1000000, $, \ 0A, A <LINE THAT ALLOWS SENSOR TO BE SET
                                                        TAKE TEMPERATURE DATA TRO/TR1 via serial port
COMPUTER PROGRAMMING - SET OF EVENTS
> SED00 TT00 + + IN SCC00R SGN {} <COUNTER RESET TIME DELAY
> SED01 TD02-+ | DC01-+ + PI LOGTRM STD02 {*} <POSITION WITH REP. POS. EXT. 45 DEGREE OR MONEY TYPE PF A IP0, LOG, TRM
> SED02 IN00 + - + IP LOGTRM <PANIC BUTTON WITH REP. POS. EXT. A IP0, LOG, TRM
> SED03 IN01 + - + IP LOGTRM <ACTIVATION OF PARKING WITH REP.POS. EXT. THE IP0, LOG, TRM
> SED04 IN01-+ + PI LOGTRM <OF PARKING WITH DISABLING REP. POS. EXT. THE IP0, LOG, TRM
> + & IN06 SED05 CC00 + - + IP LOGTRM <DISCONNECT FROM BAT. MAIN. WITH REP. SYSTEM STATUS POSITION WITHOUT THE LOG AND THE PORT TERMINAL
> + & IN06 SED06 CC00-+ + PI LOGTRM <CONNECTION OF BAT. MAIN. Reconnected with SYSTEM STATUS REPORT NO POSITION TO LOG AND THE PORT
TERMINAL
> SED07 AR00-AR01-+ PI & LOGTRM <OF BAT. AUX. WITH LOW SYSTEM STATUS REPORT NO POSITION TO IP0, LOG AND TERMINAL
> SED08 EV07 + - + IP LOGTRM <OF REST. BAT. AUX. WITH LOW SYSTEM STATUS REPORT NO POSITION TO IP0, LOG AND TERMINAL
> + & IN07 SED09 CC00-+ + PI LOGTRM <INMIGCION ON WITH REPORT OF POSITION EXTENDED TO IP0, LOG AND TERMINAL
> SED10 IN07 + - + IP LOGTRM <INMIGCION OFF WITH REPORT OF POSITION EXTENDED TO IP0, LOG AND TERMINAL
> SED11 CC00 + & GM00-+ + PI LOGTRM <SIGNAL LOSS REPORT GPS POSITION WITH EXTENDED TO IP0, LOG AND TERMINAL
> SED12 GM01-+ - PI LOGTRM <SIGNAL RECOVERY REPORT GPS POSITION WITH EXTENDED TO IP0, LOG AND TERMINAL
> SED13 SG16 & GS00 + + + PI SAU01 LOGTRM {} <STOP ENGINE LESS THAN 10KM / H ACTIVE OUTPUT 0 WITH REP. Of POS. IP0 EXTENDED TO, AND TO LOG
TERMINAL
> SED14 SG16 + - + IP LOGTRM SAU00 {} <ACTIVATION OF MOTOR OFF EXIT 0 WITH REP. Of POS. EXTENDED TO IP0, LOG AND A TERMINAL
> SED15 IN07 IN01-&-+ + PI LOGTRM <POWER TO UNAUTHORIZED CONTACT WITH REP. Of POS. EXTENDED TO IP0, LOG AND A TERMINAL
> SED16 IN01-& TD03-+ + PI LOGTRM <UNAUTHORIZED MOTION TO 250 MTS. WITH REP. Of POS. EXTENDED TO IP0, LOG AND A TERMINAL
Reconfiguration to route
> SED17 CC00 + & GS01 + - + IP LOGTRM STD02 {*} {} {SDC01 STD02000900000000 * 020} <OF SPEEDING TO EXCEED SPEED MODE DETECTED IN TRAVEL GS01 +
> SED18 CC00 + & GS01-+ + PI LOGTRM STD02 {*} {} {SDC01 STD02000600000300 * 045} <RETURN BY WAY CITY
REPORTING AND SUPERVISION OF ANALOG INPUT 0 IN04 IN05 and analog input 1
> SED35 AR03 + + AD IP TRM LOGTRM <RESTORATION MONITORING THE TEMPERATURE RANGE ANALOG INPUT 1 IN5 03.50 - 14.00 VOLTS SAR03
> SED36 EV30 + + AD SAU2100135 LOGTRM {} <RUNNING OUT 2 THE ASSISTANT FOR 13 SECONDS TO NEGATIVE SIREN, LED INDICATOR OR OTHER PERIPHERALS
> SED37 IN03-+ PI LOGTRM <SUPERVISION OF PROPER OPERATION OF ELECTRIC FAN WITH REP. POS. EXT. A IP0, LOG, TRM
> AR04-+ AD SED55 LOGTRM <DRIVE TEMPERATURE MONITORING OF ANALOG INPUT IN4 RANGE 0 00.40 - 14.00 VOLTS SAR04
> SED56 AR04-+ + AD LOGTRM <RESTORATION MONITORING THE TEMPERATURE RANGE ANALOG INPUT IN4 0 00.40 - 14.00 VOLTS SAR04
> AR02-+ AD SED57 LOGTRM <DRIVE TEMPERATURE MONITORING OF ANALOG INPUT IN4 RANGE 0 03.40 - 14.00 VOLTS SAR02
> SED58 AR02 + + AD LOGTRM <RESTORATION MONITORING THE TEMPERATURE RANGE ANALOG INPUT IN4 0 03.40 - 14.00 VOLTS SAR02
Management reports on ROAM
> SED50 TD00-+ + PI LOG <TD00 TRIP
> SED51 GR04-+ + NN {SLD IP0 SGN,, 50} <FILTER EVENTS, JUST SEND SED50
> SED52 GR04 + - + NN SLD IP0 SGN {,,} <FIJTRO DESACTICVACION OF EVENTS
EVENT REPORT TEMPERATURE SENSOR = sensor temperature SUC1 using TR1 / SUC2 = temperature sensor using analog input 0 IN04
> SED53 TD04-+ + U1 LOGTRM <EVENt 53 POSICINAMIENTO REPORTING DATA WITH TEMPERATURE SENSOR USING TR0 GTE-1
> SED54 TD05-+ + U2 LOGTRM <EVENt 54 POSICINAMIENTO REPORTING WITH TEMPERATURE USING DATA IN04 analog input 0
> SED88 GR00 + - + IP LOGTRM <GSM SIGNAL NOT VALID
> SED89 GR00-+ + PI LOGTRM <GSM SIGNAL VALID
Control failed delivery reports.
> SED90 RE82-+ | RE83-+ + IN SCT00 SGN {+1} <INCREASE PER METER FEEDBACK OR REPORT OF LOG He skipped
> SED91 RE81-+ + IN SCT00R {TRM} <EXCHANGE COUNTER ZERO Every time a report was accepted
> SED92 CT00-+ + PI SIPS LOGTRM {*} {SCT00R} <OF CHANGE IN THE ALTERNATIVE WAY IP configured and resets the COUNTER
> SED93 GR01-+ + PI LOGTRM <GPRS SIGNAL VALID
> SED97 LP01-+ + PI LOGTRM <A LOW INCOME
> SED98 EV97 + - + IP LOGTRM <LOW OUTPUT
> CC00 + + PI SED99 LOGTRM <INITIALIZATION OF EQUIPMENT
COMPUTER PROGRAMMING - REPORTS
> SLD IP0 <DOWN AUTOMATIC EVENTS IP0
> SLDE <RESTART THE DELIVERY OF EVENTS LOG UATO
> SDAIP0EA <BORRO ALL REPORTS PENDING IP0
> SDAIP1EA <BORRO ALL REPORTS PENDING IP1
> SDASM0EA <BORRO ALL REPORTS PENDING SM0
> SDASM1EA <BORRO ALL REPORTS PENDING SM1
> SUC03 QVR, 4.19 | $ GTE Trax S6 V.5.00. FINAL # <SET CUSTOM FOR REMOTE COMMAND "QUS03" VERSION OF CONSULTATION AND PROGRAMMING
> SEDU55AA <
> SSR55AA * <RESET TEAM 5 SECONDS AFTER RECEIVING THIS COMMAND
