IMEI alias on GPRS command parameter???
Тема: IMEI alias on GPRS command parameter???
Hello, is it possible to put an alias on the GPRS command parameter that sends the unit´s IMEI?
I have a test unit that I use to test different trackers of the same model.
I use about 10 commands, and the GPRS command parameter I use is, for example:
**,imei:1234567890,X
Then each time I want to test another tracker, I have to change the IMEI on all the commands.
Is there anything like an alias that repeats the unit´s IMEI typed in it´s properties settings?
something like:
**,imei:%UNITIMEI%,X
Thank you.
