Maximum sensor value between 2 geofence
Topic: Maximum sensor value between 2 geofence
My customer would like to receive a notification with the maximum value of a temperature sensor from when the vehicle leaves a geofence until it enters another specific geofence.
Is it possible to do this?
Re: Maximum sensor value between 2 geofence
I assume not possible without custom development. If you have just several geofences, and the rides are mostly the same, try the Trips Between Geofences table:
https://wialon-help.link/1c9e15dd
It has plenty of columns, including temperature.
Tnx, it's a good solution.
