Topic: API methods to perform "Check VIN" functionality
Hi Team,
I was working with Wialon Remote API requests. I have found API methods to update each profile fields such as vehicle_class, vin, brand, model etc. using the command "item/update_profile_field". In our Wialon Management System, found an option called "Check VIN" in the "Profile" tab of new unit creation which will automatically generate values for fields such as brand, model, year, engine parameters etc. on click. I would like to implement this "Check VIN" functionality programmatically. But I was not able to find any API methods for the same. Could you please help me with a solution for this.
Thanks,
Jisna
