Fuel consumption
Topic: Fuel consumption
Hello, I am looking for a fuel consumption tracker for my car. If possible, I would like to connect it to an app so that the data is automatically saved and I can track the dynamics. Could you please tell me what options are available? Or is it enough to install the application and no devices are needed?
Fuel consumption
Re: Fuel consumption
Hellen there are a lot of peculiarities, that should be considered for the fuel monitoring. The simple option would be to select a few popular OBD trackers and contact the manufacturers directly to clarify if their tracker can retrieve fuel data for your car specifically:
https://gurtam.com/en/gps-hardware/obd
It is not clear what application do you mean, but it probably will not be enough, since the system should somehow get fuel readings from the car.
