Topic: SPOT Gen4
Good afternoon everyone, does anyone know how to successfully configure the Spot gen4 device in Wialon? The problem is that you cannot configure the IP and server on this satellite device.
Hello!
Create an XML Feed as instructed
https://www.findmespot.com/en-us/suppor … pi-support
Next, copy the feed ID.
In Wialon, select the SPOT Gateway device type.
To the right of the "Device type" field, click on the image of the wrench. You will be taken to the unit's additional settings.
Paste the feed ID into the appropriate field.
Save everything. Enter Unique ID. If everything was created correctly, the data will appear in Wialon in a few minutes.
