Тема: Position devices based on beacon messages
Hello,
I'm working with the EV-05 from EVIEW and looks a very good device. I've also manage to translate in Italian the voices and watch messages.
Now I'm writing here because the device is capable to operate with beacons and AP (called Home-Wifi) with these is featuring the possibility to advise when it come close to a knowed beacon or Wifi transmitter. When this occour is also meaning that the GPS is no longer available.
Because the device can send LAT and LON together within the same messages advising is entering in the range of a veacon or wifi it will be fantastic to use these values and reposition the device.
Typicall application is for safety, when a person is outside we should know the position by getting the GPS signal, but when is entering in a place where the GPS signal is not available I can put a Beacon transmitter and be informed immediatly of the new condition, unfortunatly the position of the device is the last know GPS position. In this way I can track people or asset even if these are moving in an area where the GPS signal is not available.
best regards and have a wonderfull 2022
