Error using $wialon_api->messages_load_interval
(edited by Snakebytes888 06/12/2021 11:54:28)
Topic: Error using $wialon_api->messages_load_interval
Hi there!
I am trying to load the messages using an Class i downloaded from Github but i am getting an error saying:
{"error":4,"reason":"WRONG_PARAMS"}
Here is my code:
<?php
    include('wialon.php');
    $wialon_api = new Wialon();
    // old username and password login is deprecated, use token login
    $token = 'mytokenhere';
    $result = $wialon_api->login($token);
    $json = json_decode($result, true);
    if(!isset($json['error'])){
        echo $wialon_api->messages_load_interval('{"unit":24611387,"timeFrom":1073741831,"timeTo":1638201710,"flags":0x0001,"flagMask":0xFF01,"loadCount",100}');
        $wialon_api->logout();
    } else {
        echo WialonError::error($json['error']);
Thank you
Re: Error using $wialon_api->messages_load_interval
Try to change flags parameter
"flags":0x0001 -> "flags":1
Thank you shmi. i tried that too, but i still get the same error.
You get WRONG_PARAMS response because you pass wrong parameters. Check https://sdk.wialon.com/wiki/en/sidebar/ … d_interval
unit- > itemId
"flagMask":0xFF01 -> "flagMask":65281
Thanks a lot shmi! it is now working!
