Data from PIUSI
Topic: Data from PIUSI
Hi
A customer recently installed a PIUSI tank solution. They are using the B:SMART solution.
With the solution every driver has to enter a unique code, and vehicle id.
This data would be wonderful to get into Wialon.
Do anyone have experience from PIUSI?
Is it possible to export data, and import it to Wialon? Or to integrate?
Best regards
/bjorn
Data from PIUSI
Re: Data from PIUSI
Hi Ursus,
I am a developer and it is an interesting topic for me. From the Wialon side it is possible to integrate data from other systems into it.
But(!) the questions are:
- how should it work? You / your client should define a specification.
- does this tank solution have an API? Is it possible to communicate with it? Is it possible to export data from it?
If you want make a solution please contact me.
Data from PIUSI
Re: Data from PIUSI
Hi
I posted here in the forum as a first survey.
But so far low response :-)
I've made some research on the internet, and as I can see it there is no API.
But sometimes companys are a little bit secret about it.
The same goes for export, I do not know.
I have to find out at the customer site.
It's a Italian company, perhaps a partner in Italy knows something.
/bjorn
Data from PIUSI
Re: Data from PIUSI
Normally it is better for the manufacturer to have an API, so their product will be more open for integrations, which means it will be more popular.
Please let me know about the results smile
