Possibility of customizing ECO Driving Rank
(27/08/2021 17:34:09 отредактировано hhamedk)
Тема: Possibility of customizing ECO Driving Rank
Hi GT
The Rank parameter is a good parameter to understand the quality of driving based on ECO Driving criteria. But, unfortunately its calculation formula is fixed and doesn't work for most of our client. We have tried to use other system elements (Sensors, Notifications, Report's Custom column, etc.) to create something like ECO Driving Rank but customized but we couldn't reach a working one.
It would be great if you change the Rank and give users possibility of defining calculation formula for that. What I have in my mind is:
1. Possibility of changing the range of Rank (now it's 1-6, we may want 0-50 or 10-143, or any other range)
2. Possibility to defining the number of violations for each number of range. It means that each number of range has the threshold number of violations and as the number of violations reaches to the threshold the Rank will changes. i.e the range is defined as 0-100 and the user wants to define thresholds like:
0-10
11-20
21-30
31-40
41-50
51-60
61-70
71-80
81-90
91-100
101-110
111=<
OR
0-5
6-17
18-45
46-90
91-97
98-100
101=<
OR
Any other customized thresholds for each Rank value.
Re: Possibility of customizing ECO Driving Rank
Yes - customer should have flexibility to provide it's own ranking system
Cheers
GT, no response on this case?
Gurtam Team,
In addition to possibility of custom rank , user should be able to define own criterion for duty hours Infringement report.
Cheers
(08/09/2021 18:15:58 отредактировано hhamedk)
GT please make some noise ;-)
Dear hhamedk, Gabbar,
Thank you for starting a discussion of the Eco Driving feature.
We have previously received some similar requests on that and have tasks in our list of future improvements.
However, we have no specific requirements of how that should work. Also we do not have time frames of the changes to be implemented.
Personally, I fully agree with you that current 6-range score rating is not easy to understand, not transparent enough and not flexible as it is expected to be.
Once the feature is prioritized to be improved, we will contact you directly in order to collect all your requirements and improvement suggestions. Please feel free to add any additional suggestions regarding ECO Driving to that thread.
К сожалению, у вас не достаточно прав для просмотра данного текста
Maryia Paklonskaya
Wialon Business Analyst
"The important thing is not to stop questioning" (c)
mapa any update in this case?
Dear hhamedk,
We are analyzing the possibilities for improving the functionality of the module.
Yan Subotkin
Business Analyst
(13/08/2022 10:01:21 отредактировано hhamedk)
jasu And may I know how long it will take?
Dear hhamedk,
Since this feature is not prioritized to be improved, I do not have exact timeframe's right now.
Yan Subotkin
Business Analyst
