Topic: Unit 'A' triggers send command to unit 'B'
Does anyone know if it is at all possible to have one unit's properties or state trigger a command to a second unit?
Scenario: Unit 'A' is in a trailer with a security system that alerts if the trailer is broken into. We wish to have the state of the alarm system report to the driver silently in the cab that has telematics unit B. We could achieve all the possible states through a tractor trailer wiring (Suzie) connection, but this relies upon permanent connection and could provide a single point of failure or for a criminal to cut the wires externally. If we could achieve this via GPRS and Wialon, this is more secure and harder to attack.
I can not see how we can trigger a command to be sent based on the status of a different unit that the one that is the trigger / notification source.
There is of course other scenarios that this would be useful for, but I do not wish to divulge some of our more sensitive work, and we know we could have the units communicate directly over a Bluetooth channel, but the same cabs and trailers are not always used together.
