Combine fuel fillings & utilization cost tables
Тема: Combine fuel fillings & utilization cost tables
If clients want to see automated and manual fueling events, including the cost and other columns from the Events Registrar, they have to add two separate tables to the report; Fuel Fillings & Utilization. Currently the only field they can add from the attached image is 'Description'.
This means that the they have to export two separate tables and use Excel to combine the data, instead of being able to do it within the Wialon ecosphere.
It would save time to be able to combine these columns into one table, to produce a summary of both manual and automated data.
  • Combine fuel fillings & utilization cost tables
Re: Combine fuel fillings & utilization cost tables
Dear dan@lvmtech.com,
Thank you for your message and detailed description of the problem.
Please consider using our application Fleetrun https://gurtam.com/en/fleetrun. It is dedicated to the maintenance and fuel costs planning and control. Please see attached the form for fuel filling registration. I think this is the easiest and fastest way to get the solution which will allow you to manage vehicle's costs in one place.
Please let me know if there are any questions.
Maryia Paklonskaya
Wialon Business Analyst
"The important thing is not to stop questioning" (c)
