Filter disable for TPMS data msgs with parameter shown as sensor value
Тема: Filter disable for TPMS data msgs with parameter shown as sensor value
I am trying to use the filter function in the sensor values messages type, but this filter is disabled for data messages with the
parameters shown as sensor values
https://docs.wialon.com/en/hosting/user … ges_filter
The sensor values is very important for TPMS tyre pressure management, especially  when values need to be checked over time
Can the filter be enabled for data message with parameter shown as sensor values?
Example: I would like to select a specific sensor and filter all the empty readings out to make the list shorter
Re: Filter disable for TPMS data msgs with parameter shown as sensor value
Dear tyretrack!
Thank you for posting your improvement suggestion!
However, I think that your core need is not in the search improvement but in hiding the empty rows and\or selecting the specific sensors, isn't it?
By the way, have you used the Reports to display data for the needed sensors? By using the mask of the sensor you could create a report to display information about the specific sensor only.
Looking forward to your reply!
К сожалению, у вас не достаточно прав для просмотра данного текста
Maryia Paklonskaya
Wialon Business Analyst
"The important thing is not to stop questioning" (c)
