Easy Way of Executing the Track of the Last Trip
(edited by Fernando Brochetto 27/01/2021 20:04:35)
Topic: Easy Way of Executing the Track of the Last Trip
Hello,
Sometimes when you need to know in a easy way where the vehicle was and where it is going is difficult because when you execute a track, if you execute the track of the day many times it have a lot of content (or nothing), if you execute in a short period you don't know where the vehicle was parked.
Solution:
Create a filter to see the last trip. If the icon of parkings is enable it will show where the vehicle was parked with the duration. This tool would be very usefull to use in the monitoring list.
  • Easy Way of Executing the Track of the Last Trip
Fernando Brochetto
Technical Support, Rastreasul
fernando@rastreasul.com.br
Re: Easy Way of Executing the Track of the Last Trip
Hi Fernando Brochetto,
Thank you for the suggestion!
But I am not sure I got your idea correctly. Do you mean to add to the "Quick track" settings an option "Last trip"? With its help there will be less content on the tracks map, is that correct?
Looking forward to your reply.
Maryia Paklonskaya
Wialon Business Analyst
"The important thing is not to stop questioning" (c)
Hello mapa, yess
Fernando Brochetto
Fernando Brochetto,
thank you for the reply! The suggestion has been added to the list of improvements. Once there are any changes - I will let you know.
Unfortunately, you are not allowed to view this text
Maryia Paklonskaya
same request that i recieved form my client yseterday
In the same improvement, generating quick tracks, I believe it would be important to also be able to select the custom range inside the tab when the customer wants a specific range, and not in the tracks tab.
Fernando Brochetto
