Machine Start Report
Тема: Machine Start Report
Hello Everyone
we have a problem we used teltonika fmb125 in machine and we want to create a report for engine start how can we do that please guide if you have any ideas..
Thanking you
Re: Machine Start Report
There was a discussion in this about ignition off: https://forum.gurtam.com/viewtopic.php? … 25#p186725.
I'm not a expert in this field,but the report  maybe count a boolean value when the   ignition  it's on and off,during a time and calculate a difference of value between them.The machine it's on,the report will count the time when the ignition it's on,wich could be the inverse procedment that was said in the topic.
nowucsm, would you please explain your case in details? What you exactly looking for?
hhamedk  Hello
We are using teltonika fmb125 device and we want report of  engine start and engine off only not for ignition what connection we do at the time of installation and and what configuration we do at time of device configuration ?
nowucsm, generally Teltonika devices have an option in their configuration application called source of ignition (something like that). You can configure the way that device detect ignition. First you should decide how you want device to detect ignition, check possible options in configuration application, choose one and let us know what you have choosen. Based on that I'll try to help in how to configure, install and create necessary sensors in Wialon to get what you want from the report.
