Topic: How To set unit for CANiQ devices in wialon for Canbus data
Hello Everyone
Im using wialon and i want to use CANiQ Devices in wialon how can i impliment in wialon and how to set parameters in wailon unit
thanks
Hello Everyone
thanks
Hello,
Do you mean this one: CelloCan IQ?
The list of parameters can be found on the next tab of the same page.
zark Hello
yes CelloCan IQ If I create a sensor using Parameters, will the report be a Human Readable or will I have to create another template for this?
It depends on the sensors and reports you create.
If sensor type is chosen correctly, parameter is also connected with columns in report tables correctly. Result will be Ok in most cases, but definitely some issues should be investigated additionally with 24/7 support team via support@gurtam.com
