View our custom arcGIS map to the user using js SDK
Тема: View our custom arcGIS map to the user using js SDK
Hello,
We have uploaded a new ArcGIS map to our account, the map appeared in the Wialon local system in the map list normally and it's ok.
Now I have to develop a custom app for one of our customers and load and view the newly added ArcGIS map for him, Could you guide me from where can I start in SDK? since you already implement it in Wialon.
I need to load this ArcGIS map using Wialon SDK or by remote API.
FYI:
ArcGis hosted on the following server: www.iraq-gis.com{
I can get an image for each request in the browser like this:  https://www.iraq-gis.com/mahala/{z}/{y}/{x}
How Wialon can render this ArcGis map on UI for the user as you have done?
Regards,
Thanks
(02/01/2021 11:41:04 отредактировано hhamedk)
Re: View our custom arcGIS map to the user using js SDK
Fadi Ramzi, as I know Wialon requests ArcGIS tiles from client side, means as you login to Wialon your PC (client) requests ArcGIS tiles. So, there shouldn't be a specific API (SDK) request for such case.
As you mentioned you can request map tiles with example request, so you just need to use Leaflet, OpenLayers, etc. (I personally prefer Leaflet ) to load such tiles in your application.
@hhamedk
I have used leaflet as you mentioned and its work.
Thanks a lot
Regards
