Sky Microwave CAT-5
(26/12/2020 21:41:15 отредактировано pdvrk)
Тема: Sky Microwave CAT-5
Hi guys,
can someone help me to configure this device for GPRS tracking. Description on product page of the manufacturer says that it supports GPRS tracking but there is no commands in manual for GPRS config (APN, server, ip). Thanks!
Sky Microwave CAT-5
(26/12/2020 21:34:59 отредактировано hhamedk)
Re: Sky Microwave CAT-5
pdvrk, do you mean Sky Microwave? If you mean Sky Microwave then as I know those devices have different commands based on different regions that the device is sold. Please clarify which region is your devices (take a photo and share here)
Sky Microwave CAT-5
(26/12/2020 21:41:35 отредактировано pdvrk)
Yes, you are right, it's Sky Microwave, my mistake (title corrected). I don't know how to determine region, do I need to open the device and take photo of board? I only know it's purchased long time ago and not used at all. Here is the photo of whole set and device itself.
Sky Microwave CAT-5
Sky Microwave CAT-5
Sky Microwave CAT-5
Sky Microwave CAT-5
[user]pdvrk[/user, do you have any serial number? or photo from gift box?
Sky Microwave CAT-5
I have only this sticker on the side of the device, nothing else.
Sky Microwave CAT-5
Sky Microwave CAT-5
pdvrk, please check below commands:
GPRS Configurations:
*GPWD*GPRS:[NetAddr],[Port],[Interval],[APN],<UserName>,<UserPassword>#
GPWD is device password, 8888 is default. Interval is connection interval.
Interval:
*GPWD*GS:XX,00#
Please note that XX should be from 01-99 and is in 20 seconds units, means if you set 03 then it will be 03x20=60 seconds.
Distance:
*GPWD*FD:xxxxx#
xxxxx range is from 00300 to 50000 meters
I hope this help you.
Please inform me about the result.
Sky Microwave CAT-5
Yes! That's the solution. I've already tried that commands but with default *1234* password and always got 'Invalid command' message from tracker, with *8888* everything works perfectly!
Thank you hhamedk, you helped me a lot!!!
Sky Microwave CAT-5
pdvrk, don't mention it.
