Topic: Using Geoserver
Hello,
I tried to add a GeoServer map on Wialon local but no hope, Can anyone helps me to set the right settings
Hello,
mabed, you can leave Base layer field empty. Map Servers are addresses of requesting tiles from your GeoServer, like:
http://example.com/geoserver/gwc/service/gmaps?layers=ggrco:firstlayer&transparent=true&format=image/png&zoom={z}&x={x}&y={y};http://example.com/geoserver/gwc/service/gmaps?layers=ggrco:secondlayer&transparent=true&format=image/png&zoom={z}&x={x}&y={y};http://example.com/geoserver/gwc/service/gmaps?layers=ggrco:thirdlayer&transparent=true&format=image/png&zoom={z}&x={x}&y={y}As you can see servers are seprated with ";"
and finally Map Names are names you want to give to each server tiles (more likely name of layers) and each one is related to one server address like:
Layer One;Layer Two; Layer threeas you see here we also separated names by same character.
add a vector and raster data source to GeoServer. apply color to map features using styling. test the layers in a simple web map. learn about clients that can display your maps. add a layer from a NetCDF file.
http://bankslogin.onl/state-farm-bank-b … ard-login/
