Topic: raspberry pi to wialon - protocal
Is that possible to send the message from raspberry pi to wialon. if yes which protocol is suitable for this scenerio.
sathartpp You should develop your own application which sends data packets to server/port via direct TCP or UDP connection.
You can use Wialon IPS https://gurtam.com/en/gps-hardware/soft/wialon-ips or Wialon Combine https://gurtam.com/en/gps-hardware/soft/wialon-combine protocols (protocols' descriptions you can find on the pages)
