Topic: Engine Hours Counters
Hello,
one of my clients has some units and he wish to use this counter,
the number that he has is more that 8 digits, but the counter digits limit is 7
is it possible to extend it?
Best Regards
Hello,
Best Regards
Hello dear Hasan hasan.ahmed,
If I understand you correctly, you mean the setting "Current value" for Engine hours counter that is shown on the "General" tab of the unit settings (please, see the attached screenshot). If so, then the maximum number of digits before the decimal point in the value is 12.
If I made a mistake, please, provide more details about your request.
yes, thats what i mean,
i tried to entter 12 points, it says invalid input
please try it
if you want i can record a video
the error appear after you press the ok button
Hello hasan.ahmed,
I tried again to save the 12-digit value more and this time the error was reproduced. Indeed, the maximum number of digits before the decimal point in the value can be 6. Tell me, please, why do you still need to specify a value greater than the current? After all, the maximum possible value at the moment is 999.999 hours, which is approximately equal to 115 years of work.
Could you give examples of transport where this value is greater?
i didint measure it this way, after doing the calculation i was shocked it was 115 year, and i also called the customer and he was shocked too.
thank you 6 digits is enough
maybe the counter has wrong data
Hasan,
I'm glad we figured that out. Now the interface is a little misleading. We'll limit input to six digits, excluding the fractional part.
