Тема: Report for units that engine not working more than 2 days
Hello Dears
Our client needed a report for units that IT'S Engine not working for more than 2 days. is that report available?
Thanks
Hello Dears
Thanks
Hello,
Probable solution:
1) Create a digital custom sensor to control ignition off status. Let's say this parameter is "ign". Then use the following expression: const1-ign
2) Create a report template with a table "Digital sensors" including columns "Sensor", "Duration" and others you want.
3) Switch to the tab "Settings" and add some intervals filtration. First of all use the name of the sensor from step 1 as sensor mask. After that set min duration filter to 48:00:00.
can i have duration for more than 100 hour?
The table shows actual duration of the digital sensor active state, so it can be more than 100 hours.
But filtration by duration has maximum bound about 99 hours.
If you want to filter more than 100 hours, please direct you request to the special forum branch.
Hello Dears
Thanks
Hello Dears
Thanks
the Gurtam support already replied on this question.
