Get current unit position
Тема: Get current unit position
Hello friends, it is possible to get the current position of a unit with the API.
What method should you use to get the current position?
Thank you all!
Saludos,
Sauro Dev
Re: Get current unit position
Hi Jose!
you can use method search_item with flags = 1025 (1 - base flags + 1024 last message and position )
Diana Cheley
Wialon Hosting Expert
(27/06/2020 14:41:10 отредактировано sathartpp)
If you are looking for remote api you could try this.
Note :  replace the sid value
https://hst-api.wialon.com/wialon/ajax.html?svc=core/search_items&sid=“wertyuiuytrewertyuio”&params={"spec":{"itemsType":"avl_unit","propName":"sys_name","propValueMask":"*","sortType":"","propType":""},"force":1,"flags":4611686018427387903,"from":0,"to":0}
