Resource Filtration
Topic: Resource Filtration
Hello,
I have a small improvement that could be done:
Make the filtration of resources be the same as reports, units...
This would help when trying to find what you want.
  • Resource Filtration
Fernando Brochetto
Technical Support, Rastreasul
fernando@rastreasul.com.br
Resource Filtration
Re: Resource Filtration
Dear Fernando,
Thank you for reaching out!
Let me rephrase your request smile
What you need is to make the search in the dropdown element for the Resources to work in the same way as the dropdown search works for the "Units" and "Templates" on the Reports page. Is that correct?
I see that the problem you faced could be split into several issues:
1. At the moment the search in the Resources field searches only if the search query fully matches with the Resource name (e.g. the resource with the name "resource_test" won't be found by typing "test". It will be found only by typing the name from the first letters "resou...")
2. Only the first matching element is highlighted. (e.g. "resource_test" will be highlighted, while "resource_test_1" will be not)
3. Non-matching Resources are still visible in the dropdown
However, the current solution is applied to the several dropdown fields throughout the system which makes the changes not that easy to apply.
But we will do our best to make your experience with the dropdown elements better. I will contact you additionally once we will develop a solution for the problem.
Please let me know if I did not understand you correctly or in case you have anything to add.
Thank you,
Maria
Unfortunately, you are not allowed to view this text
Maryia Paklonskaya
Wialon Business Analyst
"The important thing is not to stop questioning" (c)
Resource Filtration
Hello mapa,
Exactly: "Non-matching Resources are still visible in the dropdown".
Thank you for your help!
Fernando Brochetto
Resource Filtration
Hello mapa, any news on this?
Fernando Brochetto
Resource Filtration
Hi Fernando Brochetto!
At the moment no positive news on this issue sad
It is not part of the development scope in upcoming month
Maryia Paklonskaya
