New axle load sensors Eurosens DPS and DDS with digital interfaces
(edited by mechatronica 05/03/2020 14:37:43)
Topic: New axle load sensors Eurosens DPS and DDS with digital interfaces
Axle load measurement and cargo weight monitoring are highly demanded options from customers. Mechatronics have developed new Eurosens DPS and Eurosens DDS sensors for air spring and leaf spring suspension.
https://mechatronics.by/en/products/loa … ad-sensor/
Key advantage  - internal data processing and digital interfaces : rs485 and CAN bus.
Comparing to axle load sensors with analog output (DPS A, earlier – Difference 01), digital axle load sensor Eurosens DPS CAN have several advantages:
1. Sensor supports several (up to 3) calibration tables. it is important when single pneumatic line connects several air springs and several axles. Same pressure will corresponds to different axle loads. CAN bus interface allows to send several axle loads calculated by new intellectual Eurosens DPS/DDS CAN sensor.
2. Better resolution and loseless digital interface increases accuracy of axle load and cargo weight monitoring.
3. Built-in calibration tables and smart data processing : sensor provides load in kilograms.
Sensors are already compatible with GPS trackers supporting the J1939 can bus protocol.
How we can connect CAN bus axle load sensor to popular GPS trackers you can read there.
https://mechatronics.by/en/portfolio-it … onnection/
eurosenstelematics.com
