Topic: Idiling time with ignition on
Hi, how can I get idliing time and moving state perfectly?
Hello!
the time is calculated on web part, there is not special parameter in any request to get such data online.
Please look here, where the same topic was discussed.
Hello!
Hi,
thanks for your reply. but the ignition value i getting is wrong. how to solve this please?
thank you
Hello!
this value means that there is not possible to get last valid values or not correct sensor settings. Could you please specify the unit (or item ID in PM) I will look through.
