Hours Format in Calculator
Тема: Hours Format in Calculator
Hello,
I have a request from some clients that are using columns provided by calculator that results in time values.
Problem:
Every new column we create with calculator, the results comes in decimal with two decimal places. This makes sometimes hard to understand values of hours + minutes or minutes + seconds for some clients. Another point is that you won't be able to see hours, minutes and seconds in the same field.
Idea:
Insert a checkbox to configure the format of the value from decimal to hours: 00.00 -> 00:00:00
Users:
Will be able to understand the values easier and manipulate them inside excel as hours.
  • Hours Format in Calculator
Fernando Brochetto
Technical Support, Rastreasul
fernando@rastreasul.com.br
(05/02/2020 09:04:45 отредактировано mana)
Re: Hours Format in Calculator
Hello Fernando Brochetto,
Thanks for your suggestion and active participation in Wialon improvement.
We already have such a request in our backlog and plan to analyze the possibility of reflecting the time in a calculator in a human-readable form in the near future.
And thanks for using the guidelines for writing requests.
Nastassia Maslovskaya
Business Analyst, Wialon
Thank you mana!!! smile
Fernando Brochetto
Dear Fernando,
We added a converter to the сalculator so that you can receive data in a readable format. Detailed information in the documentation.
Please, check it.
Hello mana, thank you, already using, it's working perfectly!!
Fernando Brochetto
