API's for panic button and unit description
Topic: API's for panic button and unit description
Hi,
We have a client that needs to send some data through a web api. He needs to send unit description from the custom fields, profile and the course.
And he needs to get some information when some units goes into a geofence.
Which commands should we use to get this info?
Regards
Adan Cabrera
Re: API's for panic button and unit description
Hello Adan,
You can use request to search item / items (unit) with flags : base flag,     custom fields, profile fields, Last message and position
To get units inside geofences there is not direct request, you can execute request presence in geofences about required point
Or it's possible on monitoring site create notification to control required geofences. Moreover, when notification triggers it's possible to execute POST request to other system (server).
Diana Cheley
Wialon Hosting Expert
