Truck Monitoring Solution
Тема: Truck Monitoring Solution
Why should trucks be outfitted with a mobile video system?
There are two main benefits:
1) to avoid accidents;
2) improve your fleet operation efficiency.
Trucks are usually large in size- that means higher risk of accident on the road. With a camera system, blind spots around the vehicle is no longer invisible to drivers. Also the mobile DVR can record and send out alarms when bad driving behaviors such as hard braking, hard cornering, rapid acceleration and speeding are detected. Even when an accident is unavoidable the video footage will be used as proof to reduce your company’s liability.
Further, in every unit of ICARVISIONS’ MDVR system we empower it with telematics fleet management technology. And this technology is visible via our Intelligent Vehicle Management System (IVMS), a software platform that can significantly help you know all details of your fleet operations with use friendly UI and various reports.
ICARVISIONS’ integrated solutions facilitate the safety of your trucks and everything on the road.
The best ICARVISIONS mobile DVR/NVR for truck monitoring:
Model#:JH8-NVR/ JH8-Hybrid series
JH8-Hybrid/ JH8-NVR series are 8CH HDD mobile NVRs that can support up to 8 channels 1080P IP digital HD video input and HDMI/VGA video output. The two models can accept up to 2TB hard disk drive for video storage and a maximum 128GB SD card for back up recording. Both models meet military grade MIL-STD 810G 514.6C-3 standard for anti-vibration and anti-shock.
Model#: JH8-HD series
JH8-HD series, 8CH HDD 720P AHD mobile DVR, is one of ICARVISIONS’ most classical MDVRs that can support up to 8 channels 720P AHD +1 channel 1080P IP video input and VGA video output. It can accept up to 2TB hard disk drive for video storage and a maximum 128GB SD card for back up recording. It also adopts MIL-STD 810G 514.6C-3 standard for anti-vibration and anti-shock.
Model#: JH4-Hybrid
JH4-Hybrid series is a 4CH HDD mobile NVR with 4 RJ45 connectors that can accept up to 4 1080P IPCams. ICARVISOINS’ hybrid video input technology enables this mobile NVR to support an extra of 4 AHD cameras up to 720P resolution. The two-in-one design gives users great flexibility to utilize this mobile NVR according to their actual demand. The storage capacity JH4-Hybrid is up to 2TB hard disk drive and a maximum 128GB SD card for back up recording. It also adopts MIL-STD 810G 514.6C-3 standard for anti-vibration and anti-shock. JH4-Hyrbid supports HDMI video output.
Model#: JH4-HD series
JH4-HD series is a 4CH HDD AHD mobile DVR. It’s ICARVISOINS’ another classical MDVR model to support up to 4CH 1080P AHD cameras+ 1CH 1080P IPCam video input. The upgraded version is now able to support VGA video output. It accepts up to 2TB hard disk drive for video storage and max 128GB SD card for back up recording. The anti-vibration and anti-shock standard of this MDVR is military grade MIL-STD 810G 514.6C-3.
All these ICARVISIONS mobile DVR models are GPS, 3G/4G and Wi-Fi optional. With 3G/4G or in-vehicle Wi-Fi connection, you can track your fleet and view live video in real timevia IVMS, even when the vehicle is moving. IVMS can support up to 10,000 vehicles and is proved to be a very stable vehicle management system over the years. Videos and other data can be uploaded to the server automatically when your mobile DVR is connected to a Wi-Fi hotspot, helping you save much labor and enhance data security.
source:https://www.icarvisions.com/Solutions/t … on-65.html
