Тема: Drones and SENSORS in HECTERRA
Hi Gurtam
As part of learning the Hecterra software, I would like to know:
If you have in the list of equipment compatible with Wialon, drones equipped with special sensors for agriculture (the use of drones equipped with sensors for agriculture that flies over farmers' fields to make recommendations to them including advice on nitrogen fertilization for example)
Do you have sensors that provide access to weather and agronomic information on plots or fields (Geofence) in real time? In other words, the sensors on the fields or parcels (Geofence) that will collect and process the data that will be sent to either Wialon or Hecterra. Weather-type sensors, anemometer, tensiometric probes, etc ... in other words sensors that adapt to crops
Today the goal for our team is to master the agriculture chain in all these aspects, with the implementation of BIG DATA, Also has a global information system of Wialon with all these components companies (Fleetrun for parts management, Hecterra for agriculture, Logistcs, etc ...) as the operation of ERP such as SAP
