New opportunities with Speed Limitation Device.
(edited by AL 07/10/2019 02:07:40)
Topic: New opportunities with Speed Limitation Device.
Speed limiter model 80 provides new possibilities to the fleet owners, GPS tracking and security providers..
It forces vehicle speed reduction or immobilization turning engine to the idle mode once getting signals from sensors or command from telematics device.
The device DOES NOT SHUT THE ENGINE OFF , this means functioning of brakes and steering is NOT AFFECTED in no reasons or circumstances!
Speed is limiting or driving not allowed if:
Seat belt is not fastened.
Entering geozone with specific speed limit.
The basket of damper truck in movement remains at the raised position.
High engine coolant temperature, low brake fluid level, low engine oil pressure, low engine coolant level, low tire pressure, exceeded distance or time period without service.
Remote vehicle (not engine shut off ) immobilization in legal and safe manner.
  • New opportunities with Speed Limitation Device.
Re: New opportunities with Speed Limitation Device.
prajwal31 wrote:
Excellent thread..!!!
I think the same:)
Many thanks !
The device can also limit the speed or turn engine into the idle mode in the following cases:
- The seat belt is not fastened.
-  The basket of the dumper truck is lifted.
- Entering/ leaving geozone with specific speed limit.
- Low tire pressure, low break fluid level, high engine coolant temperature and many other critical parametrs
- Passenger door of the school bus is not closed.
