Improve for CMS
Тема: Improve for CMS
Hello,
Can be this option added?
http://prntscr.com/p0g64a
when you have to do it one by one is horrible.
That way would make is save a lot of time..
I am not saying delete the actual way of passing objects between accounts...just asking if it can be added.
thanks
Locating things
Improve for CMS
Re: Improve for CMS
locationGPS, the button nearby a unit name should mean that this unit only should be transferred. So this column is for a unit by unit transferring. That is horrible as you said and I agree with you.
The tool that is in the panel now is aimed at plural transfer. You may prepare 50 units (give new creator required access) and transfer all 50 units in one step.
I think I don't understand your idea. But I tried to explain how I understand you. If I'm not right, please, correct me.
Tatsiana Shmihelskaya
Business Analyst, Gurtam
Improve for CMS
Re: Improve for CMS
Hi,
We pass 90% of the devices one by one to clients accounts.
so, I want to have this button.
unless are big projects, simple clients install one by one....
thanks
Locating things
Improve for CMS
Re: Improve for CMS
Hi Pablo,
you can select many units, you just need to choose selection criteria on the later screens!
(in the move units between accounts process)
Wolf.
Improve for CMS
Re: Improve for CMS
Hi, thanks wolf but I normally transfer one by one.
that is why I want the icon "pass" on each device directly.
thanks
Locating things
Improve for CMS
Re: Improve for CMS
ahh i understand.
What would be super cool: Mark unit, override all access rules and just select account to which it should belong to.
The momentan process is "not very effective"...
Wolf.
Improve for CMS
Re: Improve for CMS
locationGPS, maybe you have other ideas on how to improve the transferring process without additional columns? This option is not often used. Adding a new button will add more complexity to the system with a not required feature in most cases in daily platform use.
I may suggest a feature - you set a checkbox in a unit table, press the button in the panel, we will show this unit by default in right field in transferring dialog. Now, this dialog doesn't use selected units. This also looks not so good but may help a little.
Improve for CMS
Re: Improve for CMS
Hello,
Maybe something like this¿? http://prntscr.com/p1tidw
I understand about the column...you idea also fits mine...as at the end I must open the object card
thanks
Locating things
Improve for CMS
Re: Improve for CMS
Once again to be sure, that we talk about the same things.
The following behavior fit you:
If yes, then we can do it soon.
Improve for CMS
Re: Improve for CMS
image please to have it clear, I think we have same idea but to be sure.
thanks
Locating things
Improve for CMS
Re: Improve for CMS
Here is the screenshot
  • Improve for CMS
Improve for CMS
Re: Improve for CMS
mmmm. you mean aoutmatically will show the company where it should appear...
Well..it does not make any diference... so do not waste time doing it.
thanks otherwise
regards
Locating things
