Topic: Unique ID as parameter in notification text
Hello,
I have came across several cases where users actually would need to receive the Unique_ID as message parameter in the notification text. What I have recommended so far is to write the IMEI as a custom field and use that (since the %CUSTOM_FIELD(*)% is available).
However, this is not the optimal solution since the Unique_ID is a subject to change and will require change in the custom field aswell to be correct. If not the wrong ID will be sent.
I would recommend and appreciate a simple parameter like %UNIQUE_ID% or %IMEI% and perhaps %PHONE_NUMBER%. So that it is possible to receive real time data for IMEI.
Looking forward to hear your thoughts on this!
Best regards,
Mike
