Get geofence Area number
Topic: Get geofence Area number
How to get geofence area number by unit ? How to setup and configure?
From which API we can get this number?
(edited by muev 03/05/2019 09:15:19)
Re: Get geofence Area number
Good afternoon!
To get all the information about geozones you can use core/search_items request. The example of searching request parameters below:
svc=core/search_items&params={"spec":{
                "itemsType": "avl_resource",
                "propName": "zones_library",
                "propValueMask": "*",
                "sortType": "zones_library",
                "propType": "propitemname"
                 "force": 1,
                 "flags": 4096,
                     "from": 0,
                 "to": 0}
You can use update_zone to edit or create new geozones.
muev wrote:
Good afternoon!
                 "force": 1,
                 "flags": 4096,
                     "from": 0,
                 "to": 0}
Thanks for your answer,
But I need it by unit name if i select any particular unit and then its corresponding geofence/area number should come.
You can only get unit's position and check in what geozones it is with get_zones_by_point request.
